Turbo Porsche gets a slap!
5439cc's does not round up any way you put it.
http://www.edmunds.com/used/2001/mer...484/specs.html
Base Engine Size: 5.4 liters
http://motortrend.automotive.com/683...amg/index.html
http://www.motortrend.com/cars/2003/...ons/index.html
http://www.edmunds.com/used/2000/mer...49/prices.html
http://www.edmunds.com/used/2001/mer...74/prices.html
"This handbuilt 5.4L wonder is an all-aluminum design, replete with matched pistons and connecting rods, hand-balanced crankshaft, modular camshafts, and topped with three-valve-per-cylinder heads. A tweaked ECU and high-flow fuel injectors result in 342 hp at 5500 rpm, with torque coming in at 376 lb-ft at 2500 rpm"
So 5.5 right
, using what math? I don't know. If you're going to own one at least don't talk out your a$$ or make assumptions about a motor based on a badge. You think the 63 is a 6.3 now too?
And yes Jon, it does make a difference.
So 5.5 right
, they even made fun of that on Top Gear. Its an Ode to an older 6.3 liter motor dummy. Shows how much you know.
http://www.webwombat.com.au/motoring...-v8-engine.htm
There is a mandatory German Tax law that makes the manufacturer round up 100cc's up, but that DOESN'T change the fact that these motors are infact 5.4 liters and 6.2. End of story Jon. Change the displacement by 100cc's on ANY motor and all a sudden you make more power, it matters.
"Engine 6,208-cc AMG-built DOHC 32-valve V-8. High-pressure die-cast alloy cylinder block with twin-wire arc spray coated running surfaces." ::quoted from MBUSA
http://www.mbusa.com/models/features...E63&class=08_E
So how does 6208cc round up to 6300cc?
I just said the manuf puts a 6.3AMG badge on their cars.
No big deal but if they claim false hp like what Ford did with their Cobras back several yrs ago,that was messed up.
