Bonestock C63 vs 09 135i well modded
02 CLK 55 AMG,09 C63 loaded with P30
yeah maybe Ben's car. But if you run into an auto, theyll pull on you real easily if their full bolt on with race gas.
Example: http://www.youtube.com/watch?v=1UyiiuZshxc (335 had a boost leak, and the c63 was worked - your stock)
Once Ben has his car dialed in properly and he doesn't bog between shifts your going to need work to catch him, guaranteed. If you dont beleive me your more than welcome to run my 335 lol.
We are not discussing about full bolton here. Full bolton c63 traps 123+mph. 335i full bolton is not touching that. Anyway back to topic. We did 6 runs the last few he started to fade away right then he backed off 130 I wouldve got him few cars if he didnt back off. Mine is bonestock with the charcoal filters lol.
I suppose if you want to play that game, the first two runs if we kept going I would have had YOU by a few cars if you want to play make-believe or what-ifs.
It's amazing how a report of virtually equal runs now turns in your favor.
Well obviously not if I'm not getting the power in between shifts, its a tuning issue. I'll work on it then let's go again on Sunday. I was out making some changes to the settings on my tune as per the tuner's suggestion but just made it worse, LOL It's a work in progress.
- MHP ECU/TCU tune
- no secondary cats
- no resonater
- MHP 180F thermostat
- BMC filters
Umm, according to MHP, who produce the ECU used in the car in the youtube video, they "re-tune" the de-tuned 6.3L motor, and it picks up a substantial amount of hp; they claim that:
Originally Posted by MHP
Average gains with our v2 CDT on a C63 AMG are on the order of 60-65rwhp and 30rwtq SAE on 93 octane.
Say what? Mods listed for the E63 at the beginning of the video:
- MHP ECU/TCU tune
- no secondary cats
- no resonater
- BMC filters
This is a pretty substantial claimed gain, and I'd like to see independent verification for that level of gain (didn't think they were detuning these things by that much), but if it's accurate, picking up 60-65 rwhp is "jack" in most people's book, and I do know in any event that they're picking up several mph in trap w/these mods, indicating a not-insubstantial gain in hp in any case. And that's excluding whatever they'd get by removing the resonator & secondary cats.
- MHP ECU/TCU tune
- no secondary cats
- no resonater
- BMC filters
#32
No bog issues before meth, I would run Map 8 at the strip and slam the gears so hard and the boost would pick right back up, but with the addition of meth it becomes a whole new ballgame. I should've gotten an auto, no doubt about it. I did partially resolve the issue by lowering the meth engagement point to 7psi and increasing the bogfix feature on the JB3. I know the Procede has this issue resolved fully, so if Terry can't resolve this in a reasonable amount of time it may be time to switch. I would hate to dump the JB3 for all the support Terry has given me, but gotta do what I gotta do.
Even last year during the 1.22 - 1.3 days bogging was a big issue, especially the 3-4 shift, but it's not a problem anymore.
#33
I did not have meth on my 335 but I did on my WRX. I am willing to bet that bog you are now getting has something to do with your car running the same ign timing as it was without meth. If that is the case, you are likely losing power as soon as the meth starts to flow. I had to adv the timing 2-3 degrees when I was using meth (50/50 mix), I would talk about the fuel trim too but the WRX was not DI.
#34
Anyway, from what I've seen the C63s' non-nitrous max traps (at least in a very quick scan of dragtimes.com) are equivalent to the 135/335i max traps with it, fwiw....if this is the case, then a non-nitrous modded-to-the-hilt C63 should pull a non-nitrous modded-to-the-hilt 135/335i.
#35
So if I use your example and noting the car is not properly tuned....if the car sees a drop in temperature, it should add fuel, and if timing remains constant you will not likely see any more power.
#36
2004 S55 (SOLD, miss it every day), 2009 GL550
How do you fit a family in c63?
I could put your 63 in the back seat of my S55
on the other hand, I could almost fit my 55 in the back of the Maybach I saw yesterday.
#37
You would be surprised how much room the C63 has. I put 2 bicycles in the trunk with the rear seats folded down. Also had 6'5,6'2,6'3 guys in the car thats about 600lbs extra. They said it pulls like a **** Well I did feel the extra lbs!
#38
I'm sure headers will help (though not sure they'd help to the tune of 30 rwhp = 37 crank ), but my point was that your point that the mods on the C63 in the vid didn't "do jack" is off the mark, at least going by MHP's claimed HP increases.
When I said jack about the little mods-cat delete,resontr delete thats maybe like 15whp the most.
#39
Well, that's a total of around 50 rwhp, which should have it trapping in the upper teens, so for that Bimmer to hang with it means it's a pretty fast Bimmer in my book. Point is, those things are impressive and very impressive in the bang-for-the-buck category.
#40
I know it "pulls like a ****" (even worth 600 extra pounds of cargo), and it's a hoot to stomp on the gas
#41
Charger SRT-8
#44
1 Post
04 w211 E55
They are very fast cars and great engines for sure but these HIGHLY modded ones all have problems holding all that boost. Bogging is common in almost every modded 3.0 twin turbo 35. But when they are holding and not bogging those dam things are moving .
#47
This is my race vs the 335i... http://www.youtube.com/watch?v=emZb4B3K9Qc
#48
http://www.dragtimes.com/results.php...e=10&carmake=5
#49
btw, that 335i is fully bolted on in the E55/335i youtube video, and looks like he's suffering the same notorious JB3 6MT bog. I have heard from many fellow 6MT meth users the Procede resolves that issue, so I managed to get one for far less than market value and will try it out.
I am also going to a dyno day this coming Saturday with Jon so that we can get figures on our cars. We will definitely post our results here!
I also will have an 11 second 335i possibly coming down to dyno as well, so we will see.
#50
///M5 Beast
lol, I got my 135i for 35.6k brand new, considering I got it that fast with less than 1000 bucks in mods, I have no complaints. Final thing on my mod list needs to be a FMIC, but no rush. I don't do 6 runs back to back to back normally... usually it'd be a long pull, a cooldown period, another long pull, that's normal right? No problems equaling or beating 60k+ cars.
Yea i was in the 335i recorded in the passenger seat, he was BOgging REALLY hard, so much you can see its like he hit a wall and the E55 jumped out and in front and he was never able to catch. I could have beat this 335i in my tune only 335i for sure that night..
He was on pump gas, almost full bolt on, no meth..
