BAS ESP ETS ABS lights and brake assit pump running on
We have a 2000 (W163) and we're having serious issues with power loss and now what appears to be an aux. brake booster pump running on after we turn the vehicle off. It's also making serious noises both while drive and at an idle. The ESP ETS ABS dash lights are also on. This has been an intermittent issue that appears to be getting worse.
Any help is greatly appreciated. I'm mechanically inclined and capable of fixing the problem if I can get some sage direction as to the issue at hand.
Thanks,
Thanks,
Thanks,
I was about unplug the battery, but instead I pulled out the relay switch and replaced it with a new one ($20) and no more problems.
The relay switch that you need to pull out is the ets/bas switch.
