nav system error
Old Apr 13, 2005 | 11:37 PM
dcfsf's Avatar
2003 E55
nav system error
I get a cd-rom error when I put in the Nav CD
anyway to reset the radio or any other tricks ?
what can I expect to pay for a new cd rom nav drive? if that is the only solution?
Old Apr 14, 2005 | 01:19 AM
ML God's Avatar
Do you get the error when you use a music CD??? IF so the Nav unit is faulty....expect to pay 1K
Old Apr 14, 2005 | 09:54 AM
Wintermute's Avatar
500SEC, ML430, SLK230, S600
If the error message is limited to your navigation CD, you might consider either duplicating it (free) or purchasing an updated version (~$150). As ML God mentioned, the CD-ROM drive is somewhat expensive; if it has failed, then perhaps you should embrace the opportunity to upgrade your drive to a DVD-ROM!
Old Apr 14, 2005 | 10:43 AM
dcfsf's Avatar
2003 E55
simple overnight reboot worked for now.
It seems to be OK
Old Apr 14, 2005 | 10:53 AM
ML God's Avatar
belive me it didnt fix itself....it will do it again, and eventually it wont work at all
Old Apr 14, 2005 | 11:06 AM
Wintermute's Avatar
I'd speculate that it is probably the CD itself, not necessarily the drive.
Old Apr 14, 2005 | 01:57 PM
mihir_d's Avatar
2000 ML320 2006 SLK 350
I have had the MCS freeze on me and both the nav drive and changer give CD read error
not once, several times but only occassionaly...a reboot usually fixes it...a reboot is only accomplished by pulling the key out, not just turning the MCS off and then on - its a real pain if it does that while cruizing on the freeway...one has to pull over and stop the vehicle, pull the key out wait and then restart the truck...I think the software in the MCS is buggy & crashes/freezes at times, just like any other software....
Also, with use, the drives wear too...probably some lens cleaning might help...and of course the CD could be the culprit too, but I play my home made CDs most of the times in the changer...without a problem...
