Troubleshooting NAV issue
I have given up on trying to fix my NAV issue. Let me begin by saying that I installed it myself. It worked for a long time, then the direction arrow started to get off. It then only connected to the satellites intermittently, and finally not at all. I replaced the antenna and nothing different.
Any thoughts on how to troubleshoot this issue?
Paul
Paul
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Paul
Paul
The absolute easiest solution is to install a new antenna under the dash that is wired directly to your nav. That would also tell you for sure if the nav unit is OK.
-s-
Don't you mean on the dash? Is there any place that I can get an antenna that would work in this case, preferably not the dealer as they are costly?
You can get an antenna from a number of places. Please e-mail me if you would like a picture of one possible type.
You could hook the antenna up and lay it on the dash and try it to make sure everything works well before permanently affixing it to the underside.
-s-
MBs
![](http://www.whnet.com/4x4/pix3/gps_dash_antenna.jpg)
Taken from this page:
http://www.whnet.com/4x4/gps_antenna.html
What happens sometimes is that the 5 Volts is not fed to the back to the antenna correctly. I take a DVM and check the voltage direct at the foot on the roof, and tighten it down more in case it's not present.
comand prob
Paul.. some radar detectors affect gps receivers.. have you got one.. if so switch it off and see if your comand starts to work.... steve
