Horn died
While I was doing the oil change today, I saw the horns on each side. I slightly touched the right side one and the fricken wire fell off!
It just literally fell off with a tiny touch.So I'm guessing the horns are shot? How much does it cost to replace 'em and is it DIY?
thanks
Did it with the ML at ground level (cut the wheels to get better access.)
IIRC, the PIAAs cost around $45.
Good luck.
Good luck.
Do a search on PIAA Hi/Lo.
There are two-horn sets for around $50.
115 db, IIRC
