High idle '01 430
I've never had this occur with the 320, but when I started the 430 this morning (blocking me on my way out), before shifting the tach was above 1k RPM and didn't come down, and I waited for about a minute. Then I shifted into reverse, and the revs dropped down to about 800 (understandable while in gear). After parking it again, the revs again stabilized at about 700-800 (which is normal behavior on the 320). The question is: is this normal behavior for the 430? Does it just start high revving in the beginning to heat up the engine, or should I worry? (And no, my foot was not resting on the gas pedal! :p)
Thanks in advance.
