Changing Side Marker (repeater) Lights
Old Nov 20, 2005 | 10:40 PM
rcltrh's Avatar
1996 - C220/2001 - ML430/ 2005 RX-330
Does anyone know how to get into or remove the side marker (repeater?) bulbs on a 2001 ML-430 - the ones by the doors a little above and behind the wheel wells? The plastic housing seems firmly attached to the fenders and there doesn't appear to be any way short of removing the entire wheel well shields to get behind them. Surely that isnt the way. I have tried a few times and am afraid of applying too much pressure and breaking the lenses. Does anyone know the trick? TIA
Old Nov 20, 2005 | 11:47 PM
2mbusa's Avatar
1999 Mercedes Benz SL500 & 2009 E350 4Matic Wagon
Thumbs up Side Marker/Turn Signal Bulbs
I think if you check your manual it will tell you to slide the lens off, I can't remember if it is to the rear of the front -- would have to check my manual.
GOOD LUCK
Old Nov 20, 2005 | 11:59 PM
WienerWater's Avatar
2002 ML500,2005 Toyota 4Runner, 2006 F150 King Ranch, Kawasaki ZX1400 Ninja, 1978 Jeep CJ7
Thats what it says! Not sure, but I assume you need to lift the very front edge up a little, so it disengages, then push it/slide it back, towards the door.
Let us know what you find!
