HELP: Removing Stock Radio?
1998 ML320 + 1985 AE86
I got the 98 ML with the stand alone Cassette-Radio. I need directions for removal of this lame deck. Since my friend is dumping his WRX 6-CD indash, i am going to swap this 2 DIN in my car ....
Thanks.
Thanks.
try using something thin and very flat so it can fit between those 2 slots. if u start on the left slot theres like this spring thing it slides to the right u can feel it when your're doing it. while your're doing that pull it out at the same time so the radio doesnt go back in. and on the right slot u should push the thing to the left. and if that doesnt work. just use a screwdriver split the seam between the radio and the console. try opulling your finger bewteen them n pull HARD. it wont break. i might sound like something broke but nothin will..i did it to my ML.
99 ML 320, 97 Porsche 993 C2S, 92 300E
Very simple to remove with correct tool. It's part number 929-589-01-05-00 and costs $3.50 form a Mercedes dealer. Insert the keys into slots at the bottom of the radio and it slides right out.
