Suspension/Air Filter Questions
I just purchased a 2000 ML320, and I was wondering if its possible to raise the suspension past the stock height, and which companies would offer a kit for the ML. I am trying to add mud tires, and give the ML a more off-road look. Also, which cone air filters would work best with the ML, if any at all? Thanks
Can the ML be raised? YES, check with wolfgang for exact ideas as he is our resident off roader... You crank the torsion bar in the opposite direction to go up, Not sure how high you can raise it in the front. Not sure how to raise the rears, some type of a suspension lift kit would be needed. As for cone filters... If you browse Ebay youll come accross a ram air kit with K&N but I think most owners experience best results with a Green filter on there, which is a drop in filter. Check with Neal@euroteckmotorsports.com
He should be able to help you out with that
-Pete
-Pete
