direction to remove the navi system
Old Jan 18, 2006 | 10:16 PM
jerrymold's Avatar
hey guys i have to take out my navi system on my 2001 ml 430 to check up something like wires and other things. i need your help for direction so i wont missed it up
thank you in advance
jerry
Old Jan 18, 2006 | 10:58 PM
rcltrh's Avatar
1996 - C220/2001 - ML430/ 2005 RX-330
jerry
Insert the 2 MB radio removal key pulls into the side slots of the radio until they click, then pull it out. Simple as that. You can pull it out about 6-7 inches without unhooking any wires. If you don't have those MB removal keys you can find them on ebay or run to your local dealer and buy a pair. They're cheap.
The nav unit itself is like a disk drive that is in the very top of the case (can get to it by removing the top 4 screws, however, you can see the NAV wires without having to take the top off - they hook to the back of the nav unit. One vertical mounted harness with a press-clip lock and a single gray GPS antenna connector.
