ML rattling when cold
Old Jan 21, 2006 | 07:22 PM
akbro93704's Avatar
2014 C250 sport
In the morning when we start our ML55, the engine makes a very loud rattling/ticking sound.It also does it from 1500-2000 RPM when driving,but goes away when the engine gets to normal temp. We have had this problem checked by the dealer twice now, the first time they replaced all of the lifters and rockers, but the sound came back, so they replaced them again the second time, but it started rattling again Has anyone else had this problem, and is it really the lifters and rockers that are making the sound? thanks
Old Jan 24, 2006 | 09:00 AM
Calcio's Avatar
1998 ML320; 2005 Audi A6; 2006 Honda Pilot
E Box Fan?
Did they check to see if it was the E box fan? I would hope they did as this is a common problem. When it starts to wear, it makes a ticking sound which comes from the engine compartment. That being said, I have had to live with a loud rattle that occurs sporadically at low rpm, when stopped and only in drive (stops if I shift it to neutral). Of course, it never happens when it is in for service.
Old Jan 24, 2006 | 04:07 PM
hanniep's Avatar
01 ML55, 91 Supra Turbo, 05 Audi S4
My ML55 does this when I use cheep gas!
Old Feb 20, 2006 | 09:15 PM
RALBERT95's Avatar
03 ML350 INSPIRATION
ML500 Loud ticking noise when cold at start-up
I have had a similar problem such as yours ...with a loud engine when cold at start-up. The dealer also replaced the lifters and this had no effect. Per MB corporate...the engine internals were inspected with a boroscope and they claimed to have found carbon deposits. MB recommended the use of Chevron Fuel system cleaner with Techron every 3000 miles and the engine seems quite a bit quieter. I'm beginning to think that it was one of the fuel injectors and the cleaner dissolved the deposits within.
Old Feb 21, 2006 | 02:20 AM
pointman's Avatar
a car that can't do the throttle reset.
i have the noise as well.. the dealer refuses to do anything about it.. no lifter change, nothing.
Old Feb 22, 2006 | 08:33 AM
00ML430 Bulldog's Avatar
2000 ML430
Cracked catalytic convertors.
Old Feb 22, 2006 | 09:21 AM
55fanatic's Avatar
00 MB ML55, 91 Toyota Supra Turbo(sold), 06 E500(gone), 03 BMW M3
it is a common problem on the 55 engines... carbon deposits, go get a bottle of techron for the ML55 you will need a 20gallon treatment and a 12 gallon treatment, when the tank is near empty poor in the 20 gallon and half of the 12 gallon one, fill the tank, and then repeat once more for the next fill up, then every 3000 miles do it... wont come back
Old Feb 22, 2006 | 09:22 AM
55fanatic's Avatar
that doesnt go away when the car warms up
