tail light
Old Aug 5, 2002 | 10:36 AM
St Nick's Avatar
1998 ML 320
Question tail light
Greetings all,
I have a 98 ML320. I changed my stop light bulb (middle) with no problems. Would anyone know how to change the left brake light? I was able to take out the 2 screws, but then there is something holding the lower left corner of the light fixture.
Also, I have this rattling sound in the back when I drive. The dealer change the back seat rails, but there is still the rattle.
I tried to adjust the trunk stoppers…2 rubber like screw in the middle of the trunk door where it seals shut, by screwing them out a bit. Any other suggestions.
Thank you in advance.
Nick
Old Aug 5, 2002 | 12:05 PM
shkeller55's Avatar
1998 ML320
I had to change my left brake light a couple months ago. Seems like it's held in place by a pop-in type connector (don't know the exact technical term). I just wrapped some cloth around a screwdriver or something, so as not to damage the paint, and pried the fixture out. It came out with a pop. Once I got that out it was an easy job.
Don't have any suggestions on the rattle though.
Old Aug 5, 2002 | 12:13 PM
jswedberg's Avatar
C32 AMG
I had a rattle in the back, and it was the back hatch. I adjusted it as you mentioned, by screwing out the two rubber adjustment stops.
Old Jan 19, 2008 | 11:50 AM
mikmill's Avatar
2000 ML 320
That worked
Thanks for the advice, the tail light popped right off. Saved again by this forum!!!
