Steering Pump Seal leak and ruptured hose
MB ML 320 2001
The nearest auto repair shop quoted me $1,300 for parts and labor to replace steering pump and a ruptured hose on my 2001 ML320. Is this a fair price? I asked the mechanic for a oem pump or a refurbished one to lower costs. Any idea how much should this repair be?
Thanks,
Thanks,
05 SL500, 02 BMW Z3 (Mrs. VF), 05 FJR1300, 91 ZX-11
Sounds about $500 high to me. If you have any mechanical skills, this is an easy fix. You should be able to remove and replace the pump in a short Saturday morning.
Thanks,
Thanks,
Originally Posted by 00ML430 Bulldog
I Took it to my trusted mechanic. He found the bottom Ps hose was leaking and the ORing that seals where the PS reservoir connects to the PS pump was bad. It made the PS pump look like it was leaking at the seals. My mechanic charged me a whopping $150. I now have a dry PS pump... no leaks. try changing that Oring it is just a $6 part and the hose depending on which one is bad is about $20 or so + MB power steering fluid. ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
Thanks,
Thanks,
