Tune Up
W163 & 203
Tune Up
Hello everybody..
My 2000 ML430 now hitting 100K and I got it used...btw I live in LA so it does quite high milleage from previous owner..but it seems like they quite taking care of it....
So far I have changed the air filter from stock to K&N and it does do better for accelaration...
I m planning to do tune up0 for my car and I need suggestion what should I do beside change oil, spark plugs, transmission oil...
One more thing is there any good shop around here..I live around Diamond Bar
Your help will be great...Thanks...
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
The tranny oil thing is funny...
MB says its sealed for life, but I called my dealership and they said, although it is sealed for life, they wouldn't mind opening it, flushing it and refilling it...
W163 & 203
Originally Posted by Mugen711
for the 100K, I took my ML to a independent benz shop in Orange County, got the oil changed/tranny oil/spark plugs/fuel filter done.
btw do u have any suggestion for my catback system due I have to replace it the whole system...should I keep with original or after market...
I knw is hard to find after market..but the mechanic suggest me to keep the original part for my ML...
Thank you
W163 & 203
Yeaap I keep it in original material and according to ML430 user the cat has been an issue lately and they have tried to convience OEM to make a recall for the cat back system...
I hope they re doing it cz mine happen out of nowhere...n cat back doesnt cost cheap either....
well at least mine is done now, again thank you for your information...
I think the OEM would be good enough.
If you need a local independent shop in OC for a second opinion, I'll give you the contact info.
