Hows BAZOOKA Audio BTA10200?
03 ML500
I'm looking for a cost effective and easy removal subwoofer for my car. I came across this BAZOOKA Audio BTA10200 10" w/200-watt Powered Bass Tube & Built-In MOSFET Amplifier/Auto Turn On. I hear the name back in 90s, which I believe they were pretty popular back then but I never knew how it performed. Anyone used 1 and how does it compare to a cheap 10" Fosgate punch or a 10" solobaric.
http://www.bazooka.com/productAutoAm...sBT.asp?id=256
SL600 r230, SL600 r129,, SL500 r230, ML320, C280 Sport, 190e 2.3 16V (2)
My neighbor has a Bazooka of some sort in his CLK and is not happy with it. He likes my JL in the ML much better.
I have the JL in a box in the back, and if I need room, I simply unscrew the wires and turn off the amp. The amp is permanently mounted behind the rear pas seat, under the plastic cover that slides with the seat.
03 ML500
Here's a pic of the 12" Sub. It is heavy and just sitting there. It is not bolted down. The wire from the amp is long enough so I can put the speaker on the rear seat if I need the room in back.
I do not remember what it cost, or even what model. It has been awhile. But it sure makes all kinds of music sound better.
ps - don't mind the mess - been using the ML as a pick-up lately, hauling boat parts around.
