removal keys
Old Apr 3, 2006 | 10:19 PM
Far4u16's Avatar
removal keys
Ok this is probably the most stupidest question ever.... but for my ML320 (2001) i got the stereo removal keys... popped them in and fixed an antenna that had come loose. So I slide the unit back in.... but i cant remove the removal keys!!! Is there any special way to do this? or am i missing something here?
Old Apr 3, 2006 | 10:23 PM
jsheyn's Avatar
I suspect you remove the keys before you slide the sterio back in........so just pull it out and take the keys out then just slide the sterio back in...
Old Apr 4, 2006 | 05:20 AM
Far4u16's Avatar
I tried it, but i still cant remove the keys....
Old Apr 4, 2006 | 06:08 AM
springerfever's Avatar
1999 ML430
If you look on the sides of the radio where the keys clip in you will notice it is a spring mechanism. Use either your fingernail or a small screwdriver to 'release' the key and then remove. Then it is simply a matter of sliding the radio back in until it locks into place. Make sure the wiring harness has some play in it and is not binding behind the unit. Do not force the radio back in.
Old Apr 4, 2006 | 06:29 AM
StapleGun's Avatar
1967 Morris Cooper "S", 1983 911SC, 1997 Toyota Tacoma, 1999 HD FXSTB, 1998 C43
You don't need ANY tools to remove the tools - look on the side and it'll have a spring detent in the immediate vicinity, depress these on either side and voila!
