2000 ml 320 starts 5 min then cuts off..Help!!
Old Apr 8, 2006 | 04:09 PM
Aljeanniton's Avatar
My 2000 ml 320 started cutting off no fuel comming from the pump. but if you let it sit for 30 minutes it will start again then for 5 min then cut off? A mechanic changed the mass air flow sensor $350. I took it home same problem.. then he changed a lilttle sensor behind the engine right side,, same problem. So he changed my fuel pump $800.. I drove home same thing stuck on the road. At this point im not bringing it back to him,,anybody with the same problem? What should I do? please help... AL
Old Apr 8, 2006 | 04:33 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Get yourself a new mechanic. He is just throwing parts at it with no diagnosis. Either he has no diagnostic skills or equipment or, He is just milking the job. My guess would be either the fuel pump or the CPS and the fuel pump has been done. But, thats just a guess exactly what your mechanic is doing. Why not just go to a dealer and have him diagnose the problem correctly. Would have cost you lots less if you had.
Old Apr 8, 2006 | 04:42 PM
ok thanks, Im dying to find out what it is..
Old Apr 9, 2006 | 11:08 AM
The car is fixed, turns out it was the crankshaft sensor after all ,the mechanic used a used sensor. beware of this guy ..Mercedes Benz shop Freeport NY buffalo ave..
