one touch windows - how to
I want to setup all the windows for one touch up and down (front doors, rear door, rear cabin windows, and sunroof.
Is this something I need to go to the dealer for or can I do it myself. I read somewhere that you simply open all the windows then hold down for 10-15 secs then hold up for 10-15 secs on each window separate. This didnt seem to do the trick for me.
Anyone?
Perhaps I didnt hold the buttons long enough or there is a special sequence? Like I said, the direction I have say open all windows with key in ignition and then hold down for 15 secs then up for 15 secs on every window...
I do not have my manual as I just got the car and the dealership is looking for it (dealer car).
You press the open/close window swictch an you hold the button until you feel some resistance. This is the manual way of opening or closing the window.
To make the window open or close automatically, you press the button past the point of resistance (or press it all the way) and then you release the button immediately, and the window will automatically open or close automatically..
If you hold the swicth while it is closing, it will override the obstruction sensor and the automatic reversal feature...
If you change the vehicle battery or if the power windows are not working correctly, you need to synchronize the window system by starting the engine and holding the window switch until the window is closed and then holding it for around 3 seconds.
AC
