Painting the inner wheel well fenders...
One of the cosmetic fixes I was planning to do is to remove all of the wheel wells and repaint them...just to give it that fresh off the show room look again...
Anyone done that before? I was just planning on using regular off the shelf black paint (spray cans), or is there any special paint that I need to use?
Also, after 6 years, it is bound to lose its show room look...I want to restore it fully to show room condition and ready it up for the next 100K mile/5 year journey...
That's why I want to repaint them....
Finally went with a pressure washer running hot water through it. Worked like a champ ! If you really want to do a thorough job, remove the liners (very easy ..just remove the nylon nuts...6-8 I believe, and 'flex' the liner out.) After cleaning, use a plastic dressing, such as 303 Protectorant, and reinstall.
I would not paint the liners, that's just going to lead to problems down the road.
Oh, by the way............as long as you have the wheel liners out, its a great opportunity to change out the spark plugs and, if necessary, the shocks. Liners have to be removed for the shocks to be replaced , and gives easy access to the plugs if you decide to change them . If they have never been changed, its time.Bosch Platinum twos or fours are a good replacement.Don't forget, the 320 takes 12..the 430 takes 16.
Yep, I have the never replaced spark-plugs, fuel filter and MAF in mind...for replacement this August, when it will also need a B service. I am planning to get the B-Service done at the dealership and either DIY the rest or look for a local shop to get the rest done...
How hard is to replace the shocks? I am thinking of those too...since its 95K now, the ride doesn't feel bad at all, but it wouldn't hurt to replace them...are the shocks an easy DIY?
Sparkplugs are also easily changed. Plenty of DIY info on this and other ML sites......good luck and keep us posted !! Also we like pictures !!
otherwise just clean the tar out of them. There is no replacement for elbow grease!!One trick i can give you on detailing your wheels.... take them off the truck (maybe one at a time) and clean them inside and out. You will be pleasently surprised on how good they look after that!! I found a product at Walmart called DuPont Teflon tire dressing. Makes the tires black without the greasy look... I'm impressed with the product...
