Power Lock Issue
I have 1998 ML 320.
Since this weekend I am having wierd issue when locking vehicle with my remote. (Unlocking seems to be normal)
Usually When locking, I press lock button on remote, and it locks all doors and trunk and Turn signals blink.
Currenlty when locking, I press lock button on remote, my ML locks all doors, un locks them and then locks them again. Turn signals do not blink. Also trunk is not locked at all. If doors are locked and I open the trunk, my alarm starts.
Do you have any ideas what may be the issue and is there a way to fix it?
It looks this whole problem is caused somehow by trunk lock. If I lock the trunk manually by moving the latch on inside of the trunk, then my power locking with remote works just fine - all doors lock immediately and my turn signals blink once. Only problem is that my trunk is then permanently locked.
If I unlock the trunk manually, then I have a problem that I originally described.
Did anyone experience similar problem?
The new actuator/handle assembly will cost about $137 and purchase a 1/2 dozen of the rear hatch panel clips/studs because you will break quite a few removing the inside panel cover.
Good luck,
-Kevin
