98 died - need advice!
Old Jul 16, 2006 | 11:29 AM
frugalo's Avatar
Angry 98 died - need advice!
Hi looking for help on ID-ing the cause. I have a 98 that started to turn over with AC on then immediately died. NO POWER anywhere. The batterey has a charge (2 months old). There is no radio, no instrument panel....nothing. Any ideas?
Wiring harness?
Please advise.
Russ
Old Jul 16, 2006 | 11:58 AM
PaulX608's Avatar
2011 VW cc, 2004 ML350
If you have no power anywhere, start at the source. Check your battery. If it has power, then check it's connections, then fusable links, etc., working your way away from the battery until you find the problem.
