02 Instrument Panel Lights Dimming
Old Aug 17, 2006 | 10:27 AM
tzetter's Avatar
2002 ML 320
When I turn on my headlights, my instrument panel lights sometimes turn completely off. They will soon fade back on, then off again then on again! Other times they operate normally. I can see the clock/odometer etc all fine in the day, when the headlights are off, but when I click them on, they cut off, and then later will fade back on. Any ideas? This is driving me crazy and I'm just not sure what it could be.
Old Aug 17, 2006 | 08:23 PM
AndrewAZ's Avatar
BMW FTW
Does it sound like your engine struggles when you flip on your lights? Also do your headlights dim then go back to normal then randomly dim and go back to normal? I had that issue where when the headlights where turned on all the cabin lights would dim then go back to normal and randomly dim again. It was found that my accessory belt was lose, it was repaired under warranty the belt was replaced and they re tensioned stuff..
