Changing the Turn signal lights??
Old Aug 29, 2006 | 07:25 PM
twenty2's Avatar
ML 500 gone, ML 320 gone, C230 kompressor, & Hummer H2
How the heck do you get to the turn signal lights in the front? I'm just changing the yellow bulbs and I can't seem to get the headlight out???? I'm sweating just trying to figure it out without breaking anything. I do have the Xenon headlights if that makes a difference????
Old Aug 30, 2006 | 07:58 AM
azinn's Avatar
2014 RX 350 F Sport, 2007 Scion tC, 2000 ML 430 Money Pit Finally Gone! Oh Happy Day!
I would remove the plastic strip below each head light, then remove the three 10mm screws, then pull out the whole light assembly for easy access to the bulbs. Thats how I did my regular headlights on my ML 430. My 2 cents.
Old Aug 30, 2006 | 05:13 PM
Riffyb's Avatar
04 S500, 05 Jeep GC, 06 Acura TL, 04 BMW 530i, 98 Jag xk8,
just like azn said but.. theres a screw on the top also that needs to be removed then a small clip next to it.. once you do that make sure to disconnect the wires.. the turn signal wire needs to be twisted to come out
Old Aug 30, 2006 | 11:54 PM
twenty2's Avatar
thanks guys!! I just changed them. It was pretty easy to do. 15 minutes max for the both sides!!
