Water coming in!
Old Sep 20, 2006 | 11:21 AM
Daranello's Avatar
Question Water coming in!
Hello, my wifes 2000 ML320 has water coming in. The drivers carpet is very wet. Were do you think its coming in from? Everything looks dry around the doors. Please help. Thanks.
Old Sep 20, 2006 | 01:07 PM
rednsx3's Avatar
Hi,
I had a similar problem and it turned out to be the clogged AC water outlet.
BUT --- If you have been driving in the rain ,most probably it is the sunroof drain that is blocked.
Old Sep 20, 2006 | 03:06 PM
Daranello's Avatar
Originally Posted by rednsx3
Hi,
I have a SkyRoof (that works)....I'm dumbfounded on how to find this problem!
Old Sep 20, 2006 | 03:12 PM
NK1983's Avatar
Hi,
How did you rectify the blockage?
Old Sep 20, 2006 | 03:27 PM
Daranello's Avatar
Mine is wet from the foot brake all down on the left side (exacly were you left foot would be)
Old Sep 20, 2006 | 03:52 PM
55fanatic's Avatar
00 MB ML55, 91 Toyota Supra Turbo(sold), 06 E500(gone), 03 BMW M3
I had this problem on the right side... it was a retaining clip holding something or other down my SA said... 170 for labor, 6 for the part... no lube for me
Old Sep 20, 2006 | 08:53 PM
Daranello's Avatar
new news, there a flap on the inside drivers side fender (right were your baby toe would be on your left foot) to the upper front of the hood release that is super wet and it seams that the water is coming from this area or upward. Any idea what that flap is?
Old Sep 20, 2006 | 09:17 PM
Daranello's Avatar
The dealer also just replaced the cabin air filter (service B) is that in the same area??
Old Sep 20, 2006 | 10:58 PM
Daranello's Avatar
Hi,
Your RIGHT i pured water in the top left sunroof drain hole
(skyroof, I suposes the drains are the same) and it pured like mad all over the floorbards........
Now how do I fix this?????
NOTE: not sure if this has anything to do with it but a new windsheild was just instaled.
Old Sep 22, 2006 | 12:27 PM
rednsx3's Avatar
Hi,
Sorry for the late reply - I live in India and we have a huge time gap.
I had the local MB service center remove the blockage - I think they do it by pouring water with slight pressure to remove any dirt. If the water is coming inside then it is a possibility that the drain pipe is broken or dislocated.
I think this is something you can do yourself provided you know what to look for.
Old Sep 22, 2006 | 01:14 PM
Daranello's Avatar
Hi,
Thats the problem, I don't know where to start looking....It can't be blocked can it, becasue the water run right thru to the inside, if it was blocked would it not go thru?
Old Sep 22, 2006 | 07:09 PM
Daranello's Avatar
UPDATE: OK found the disconected tube under the dash near the foot brake. Looks like the tube takes a 90 degree turn and the sunroof tub is smaller than the one exiting the firewall. My Question is do I just connect them like (male/female) or is there a missing elbow fiting? (I will post pixs soon)?
Does someone have the online parts scematics of this area?
2000 ML320 (skyroof)
Old Sep 22, 2006 | 11:48 PM
Daranello's Avatar
How Do I Post The Pix>
Old Sep 30, 2006 | 08:42 AM
davebez's Avatar
same problem
i has the same problem. I ended up using superglue and silicone sealant to make sure the pipe did not become disconnected from the elbow again
Old Jun 22, 2008 | 07:22 PM
danriddell's Avatar
ML320
2002 ML 320 Sunroof Drain Tube
I've read through the forum on the possibility of the sunroof drain tube coming disconnected. My wife's vehicle is experiencing wet floor boards on both the drive and passenger sides. I used my compressor to blow are in the right and left drain tubes and and I could hear air being released by the wheel wells. However, I can't locate the drain tube exit. Does anyone have any pictures and/or an explanation of how to check the elbow I've read about in this forum. I would like to confirm that the elbow is completely sealed even though I can hear the blown air beneath the vehicle. Thanks in advance.
Old Jun 23, 2008 | 12:13 PM
pkimber's Avatar
ML270
I had the same problem a few years ago.
Solved it by using duck tape to make the sunroof seal better. I ran black thin strips of duck tape around the roof to build up the seal.
That was the problem, the felt sealer running around the sunroof was no longer a tight fit
Old Jan 28, 2010 | 03:26 PM
bluesky2's Avatar
M
I just tried some weedeater lines but the lines won't go too far (about 2-3 feet). probably I didn't use the right lines. Anyway, pressured air did the work. It took only one shot and the drain was opened up. This is just another way to get it fixed. Thanks for your help!
