How to change the air filter for the air conditioner in 2002 ML320
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
Thanks in advance.
'11 C300
The "cabin air filter" is what you are talking about. It filters the air coming inside the car. If your '02 is like my '03 it is up under the dash on the passengers side and is easy to change out. Just make sure you note how you take it out and how it is oriented so you put the new one back in correctly. The direction of flow must be correct. Do a search for cabin air filter and you may find more information.
1 Post
2014 RX 350 F Sport, 2007 Scion tC, 2000 ML 430 Money Pit Finally Gone! Oh Happy Day!
Thanks in advance.
'11 C300
Your post got me thinking about the filter so I pulled mine to check it. It definitely needs changing less than 9 months and about 9,000 miles. It is black with crud. I ordered the Bosch activated charcoal filter from bimmerzone for $21.25 each. Got one for the wife's C280 also. That is cheaper than what I paid for the paper one ("particulate") that is in it now at the dealer. Bimmerzone list these for $30.37. Maybe these particulate filters are better at filtering? I saw here though that the charcoal also filters out the smell; e.g., when you're sitting behind an older diesel school bus at a stop light. We'll see.
Thanks all,
I have replaced the filter. I found that it really dirty and I wondering why the filter must be replaced, not cleaned. It doesn't make sense to change it weekly, or even monthly. So I try to put a 3M filter (the normal air conditioning system filter) in the front side, and keep to replace it monthly. I think it will be healthier & cheaper to having fresh air.
Just one reminder, when you take off the cover by loosen the screws, please remember to lift up the lock in the middle of the cover (it is black in colour). It lock the cover into the filter cover. Just pull the lever out, then it will be unlocked from the filter cover. or you could just pull the cover out. I think the plastic lock may not broken. (since I have done it, and found it after I pull the cover off)
Anyway, thanks.
Anyway, thanks.
'11 C300
I just installed the Bosch activated charcoal filter for the first time (always used the stock filter from the dealer) and will let everyone know if it is better at filtering outside air into the cabin; e.g., no offensive odors. One thing that is different is that the stock Benz particulate filter that came out has a rigid plastic frame and the Bosch is all paper. The Bosch instructions say replace every 12,000 miles. Mine has never gone that long without being really funky. This last one had less than 9,000 miles/9 months. Guess it is the Virginia air or...? I never go off road. We'll see.
04 S500, 05 Jeep GC, 06 Acura TL, 04 BMW 530i, 98 Jag xk8,
I just pulled mine out and WOW!! its a mess.. im ordering one right now But what is my Chassis letter and Number? ive seen this somewhere before but i cant remember where i have a 2000 ML 55
THis is whats on the site
Chassis: -A-145272
Image ACC Cabin Filter
Also referred to as a combination filter, dust filter or pollen filter. Chassis: -X-707755
Also referred to as a combination filter, dust filter or pollen filter. Chassis: A-145273-
Also referred to as a combination filter, dust filter or pollen filter. Chassis: X-707756-
Chassis: -A-145272
'11 C300
Look at the last 7 digits of your VIN code. That is what they are looking for. It is in the lower driver's side, on the dash. You can see it through the windshield from the outside. Should also be on your car registration.
'11 C300
![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
'11 C300
If you are ordering a cabin air filter from bimmerzone then your chassis number (A284507) is greater than A145273 so pick from the third one down on their list of four to select from for the 2001 ML320. There are only two of the four to select from with an "A" prefix, one with chassis number A145272 and below that number and the other with chassis number A145273 and above. Two different ones to pick from once you click on "A145273 - " : activated charcoal and particulate. Mercedes normally puts in the particulate one, part # R2060-101103. I tried the charcoal one. I'll get the particulate again next time. See my post above on that.
09 ML320, 07 BMW 335i, 03 SL500
i ordered from importec....
R2060-138189 Acc Cabin Filter Activated Charcoal 18.70
Bosch....
hopefully thats right. thanks for the help guys.
Bosch....
just received today! wow talk about fast shipping. installed in 2 min. old one was filthy!
