ml320 Changing Brakes,screw wornout
ok i was trying to change the front brake pads,and i can take the screws where the t40 torx goes,cause they are wornout or stripped.
how can i take it out?
Just look for some tool that can unscrew jammed screws..
There are plenty of such tools in the market that make it possible to unscrew screws with broken or worn out heads...
Once the screw is out, just replace it with a new screw..don't mess the threads on the caliper while getting the screw out...else you'll need a new caliper.
