How to remove trunk panel
Old Nov 6, 2006 | 08:39 PM
MBfan89's Avatar
How do i remove the trunk panel because its starting to ratle when im goin over bumps or when my sub is bumpin
Old Nov 6, 2006 | 09:36 PM
516mbtek's Avatar
'06 CLS55 P030
its held on with the 1. the door handle bezel (phillips screw) handle, and 2. a buckload of clips that break during removal. Pull bottom part off 1st then gently work your way up popping them off w/ clip removal tool (if u have)then slide panel upward to release top clips. Have some new clips ready to replace the ones that broke during removal.
Old Apr 1, 2011 | 12:52 AM
GuyFawkes's Avatar
W163 ML430, W212 E550, R129 SL320
Does anyone know what to tighten with the trunk panel? I have a ton of rattling coming from there. Wonder if it's worth it/easy to fix.
Old Apr 13, 2011 | 11:48 PM
jbecke2's Avatar
ML55, ML320, 190e-16v...SOLD
If its the whole tailgate rattling you can try and move the stops out more. Black rubber screws, one by each taillight.
