Help with noise from dash!
Old Nov 14, 2006 | 12:09 PM
kevine310's Avatar
Hi, we have a 2005 ML 350 and recently, whenever the car is warmed up, a constant buzzing noise is coming from the instrument cluster, but nothing's loose as far as I can see. The noise can only be described like a vibrating noise and it seems to get worse when we go over a bump. Last year, we had a similar noise and the dealer replaced a fan in the fuse box, could it be the same problem this time? any idea what it is? Also, the noise appears only in winter and when the car is warmed up. thanks.
