Door locking Issues
Old Nov 18, 2006 | 02:02 PM
Riffyb's Avatar
04 S500, 05 Jeep GC, 06 Acura TL, 04 BMW 530i, 98 Jag xk8,
Exclamation Door locking Issues
Did some searching and found this thread
https://mbworld.org/forums/showthrea...chine+Gun+lock
one member is saying if its down up down its from the tailgate. If its from the tailgate then what should I do?
Im having this problem also, but my issue is its comming from my left side drivers door and right side rear passenger door. So im guessing I need to replace both of the locks. Where do i go about buying the parts?
Old Nov 22, 2006 | 08:15 PM
blueml320's Avatar
Are the two lock did not move when you lock it, while all other lock to up and down? if yes, it is sorry to tell you that you need to replace those lock without movement. I did it, but lucky, only one door.
Old Nov 23, 2006 | 06:43 AM
DUTCH's Avatar
2000 MB G500 NMLE, 2015 Audi Q7 3.0 TDI Prestige
There's a TSB out on this problem. Here's the link:
http://www.alldata.com/tsb/Mercedes-...-73/index.html
Old Nov 23, 2006 | 07:29 PM
kokketiel's Avatar
'01 ML430, '03 C320 Coupe MT, '14 GL450
That TSB seems to apply to the new ML (W164) and R class.
