Power Steering Pump issue
![Lightbulb](https://mbworld.org/forums/images/icons/icon3.gif)
I have a 2002 ML320 & I noticed my fluid level was low @ min 20 degrees celcius. Does anyone know what level should fluid be at?
Merry Christmas
Merry Christmas
1 Post
ML430, Mini Cooper S and Porsche 911 Twin Turbo
There's marks on the dip stick...
As I recall if you look closely on the PAS dip stick there are marks showing min and max at a couple of temps.
I'd check it when the engine and PAS are up to operating temp.
At the same time look for any leaks, too little oil can damage the pump.
If you need to top it up make sure you use the correct MB oil type.
