Ml270 Heater Working But Not Heating
Old Jan 18, 2007 | 07:38 AM
mhm001's Avatar
2001 ML270
Question Ml270 Heater Working But Not Heating
While Driving To Work This Morning I Turned The Heater On For About 10 Minutes And It Was Only Blowing Out Cold Air. Any Ideas What Could Be Wrong?
Old Jan 20, 2007 | 03:54 PM
KENNETH04S's Avatar
02' brabus modified ML500,05' Lambor Gallardo, 02' CLK
check AC dryer and evop, may be it's time for you to get a new set
Old Jan 22, 2007 | 06:09 AM
mhm001's Avatar
2001 ML270
Thanks for the info.
Old Jan 22, 2007 | 08:07 PM
Radomir's Avatar
2000 ML 430
Got enough coolant?
Old Jan 23, 2007 | 02:39 PM
marcelc's Avatar
2002 ML270
I've sometimes experienced cool air until the engine is fully warm, I've then switched off the ignition and restarted and the problem has cleared.
In cold weather the ML270 can take a full 10 miles to warm up, so I would not expect a lot of heat for the first 10 minutes.
Do you still have the problem?
Old Jan 24, 2007 | 06:47 AM
mhm001's Avatar
2001 ML270
Smile
Checked Coolant level and found level to be OK.
Took marcelc advise and heater worked without any problems after some time.
Thanks to you all.
