ML 320 cdi air suspension
Old Jan 21, 2007 | 01:20 PM
cd man's Avatar
We are about to order a 2007 ML320cdi and are considering the air suspension package, however, I have one salesman telling me that the ride will not be any different to the standard suspension and another saying that it will soften up the bumps and potholes, ....has anyone out there been able to do a side by side comparison....tks
Forward Message
Old Jan 22, 2007 | 08:45 AM
OttoBon100's Avatar
'11 C300
If you post this in the W164 section you may get a better response.
Old Jan 22, 2007 | 12:46 PM
fkong777's Avatar
07 GL450, 91 NSX, 12 Prius
It is hard to imagine that airmatic will feel the same as conventional suspension. salesman will tell you anything if they have a car in the lot they want to move.
ask him. how about height and damper control are they the same too?
Check with the W164 section they should have more to add.
Old Jan 22, 2007 | 02:19 PM
marcelc's Avatar
2002 ML270
Forward Message
I have driven both, the air suspension is superior both in ride and because you can adjust it, soft when the family is in the back and sports when you are alone - and it does make a difference.
You can also set it to give you greater ground clearance off-road (I am not sure if this is only available on the off-road package) and I believe it 'crouches' at higher speeds for extra stability.
The only disadvantage to air suspension might be in lower reliability and the possibility of future high repair costs.
Still, better to do the job properly if you can afford it.
