2001 ML430 GPS/Nav Problem !!!
Old Jan 27, 2007 | 12:49 PM
dean1969's Avatar
My Nav system just stopped working. The problem is there's no satellite signal. The system itself is working, but it thinks I'm 200 miles away from my actual location. The GPS antenna should be fine because TeleAid knows exactly where I'm at. Could this be a bad connection, bad splitter, etc..........
Everything has been working fine until yesterday.
Old Jan 31, 2007 | 09:53 PM
dean1969's Avatar
Problem is solved. It fixed itself.
Old Feb 8, 2007 | 12:50 AM
jerryml's Avatar
2001 ml430 sport, 97 c230
i use to have the same problem then it end up from the antenna. i bought the after market one for $45 instead of spending $240 from the dealer and it work fine for me with no problems, good luck.
jerry
jerryml's Avatar
jerry
