I need some help on front brakes
Old Feb 6, 2007 | 09:17 PM
auto art's Avatar
I am going to replace the front and back brakes and i was wondering if there is a write-up about it.Or anything spechal i should know before i start
Old Feb 7, 2007 | 12:48 AM
cward2's Avatar
2016 GTS; 2019 Alltrack; 1974 C10; 97 993 ---- Gone GLA45, APR STG3 Golf R, 2 E55's, E63S, 911's
If you're doing the pads only its about as simple as they come. Make sure you get the right pads if you have an early 430 (goes by serial number). If the rotors its just a bit more effort but not much.
On an older car, the screw holding the rotor on can be painful at times but mine were not too corroded at 90,000 miles. Just soaked in a rust dissolver spray the night before.
Chuck
Old Feb 8, 2007 | 10:32 PM
auto art's Avatar
I thought that there is alot of probloms with people with noisy brakes,and that you need to put shims or lube so that the brakes dont make noise?
