BAS/ETS/ESP light on!
Old Mar 24, 2007 | 08:38 PM
Kar don's Avatar
Mercedes-Benz
BAS ETS and ESP lights come on after start and stay on. Tried shutting the car off and restarting and the lights were off. Anyone else experience a similar issue? It is a 1999 ML320.
Old Mar 25, 2007 | 07:32 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Likely that is an intermittent brake light switch.
Old Mar 25, 2007 | 09:45 PM
Kar don's Avatar
Mercedes-Benz
thanks sosh! hopefully you are right.
Old Mar 26, 2007 | 06:38 AM
Penn's Avatar
GLE 350D GLC 250D, Previous vehicles W204, W164, W163, W210 & W202
I had the same issue caused by a faulty ABS sensor.
Old Mar 26, 2007 | 11:49 AM
hanniep's Avatar
01 ML55, 91 Supra Turbo, 05 Audi S4
Mine was a the brake light switch,..$85 and then the ABS Pump too $1600 have them run the code for the lights that will tell you whats wrong... Good luck!
Old Apr 3, 2007 | 03:34 AM
mcphere's Avatar
2006 ML500
Fix most with Brake stop switch replacement...
Fixed most of the error codes with brake stop switch replacement...around $20.00.
Here is the link I followed to replace the switch:
http://www.keysolutions.com/M-class....ent&AutoFramed
C1401 still comes up. I am going to have this double check next week.
:-) mcphere
Old Apr 3, 2007 | 06:06 PM
dewdaltz's Avatar
02ML320/06R350
:-) mcphere
Just had my ML fixed for this problem and most especially with that code. They changed the ABS relay. you know where that is? hope so. Just buy that one. I paid $170.00 for that relay + labor - of course.
