EGR Tube Removal Magic?
95 E420/98 ML320
I am trying to remove the EGR tube from my 98 ML320. I have all of the E-Bolts removed and the EGR valve and tube are free. I can't seem to get the tube out of the manifold no matter how I twist it. I always hit some interference (the throttle body mostly) before I can get it past the first bend.
I have read through most of the threads and everyone seems to say just snake this thing out, I have been working at it for about 30 minutes and can't find the magic angle to get it out for cleaning
These pictures on Benzworld have been helpful
95 E420/98 ML320
As is normal, 60 seconds after I posted the question I figured out the answer. There is a vacuum port on the top of the throttle body that has a large vacuum connector (dual port). Pop that off and move it aside and you have all the clearance you need.
The EGR tube was completely obstructed. I cleaned the first inch or so inside the tube using a battery terminal cleaner then blew the rest out with a compress (my lungs). The EGR valve seems a bit sticky but moved, I am not sure how sticky is acceptable. I will probably end up doing this job again once I can get some real brushes and cleaners.
Unfortunately the CEL (P0400) did not clear. Does this need to be reset electronically?
