98 ML320 -need help? engine dies after changing the spark plugs
Hello:
changed spark plugs 2days ago with know problem.. the problem is when you cranked up the engine the idle started to get lower until it dies out. any advice what could be wrong with the vehicle.
Tried running the car after i changed the spark plug. It seems that the computer is not reading it and i back track several times & double check everthing i did. Only i can think of is the fuel pump & fuel filter needs to be replace. Is there a way i can reset the computer?
I would go to a reputable mechanic or the dealership for further diagnostic check. You could waste alot of money and time on guess work. If you had no such issues prior to changing plugs then it may not be a fuel pump or filter issue.
