power steering leaking on lower cooler hose
94-MBC-220/03-ML320
Hi, I'm new here, first, I just want to say hi to everybody. I really enjoyed reading all the question and answers of some of the members here,that some has a problem. same thing with me.I have a Ml320.its an 03 with 46k miles i like it but the dealer replaced the lower power steering hose,coz, it came off i loose a lot of power steering fluid. second rear door latch, it wont close eventhough all doors are close. the fuel tank cover . you know the plastic lid inside the fuel door.replaced.I had this for 4-months since i bought it.Ireally don't know exactly whats going on with mercedes quality.I know they started this since they merge it with chrysler.problem started.I'm not used to this kind of problem with mercedes.
I remember I used to have a problem with power steering fluid. I always had to refill the power steering fluid. However around 80k miles i had to replace the whole power steering hose. My cd player used to not work either. But the problem went away after i had my batter replaced and had to put in the security code the radio. weird....
The ps lower line is still in warentee. I come across 1 ps lower hose a day. Also, check your ps reservoir seal, they like to leak too. As for the rear latch, I replace a few of them, they are somewhat of a common problem with door latches as well.
94-MBC-220/03-ML320
Drain trans,fluid @60K
this for motion effect question,you fix mercedes,my question is, is the transmission fluid is good up to 100K, i want to drain mine at 60K. its okey right.
Renato, you can change the trans fluid at 60k. while at it. I recommend changing the transfer case fluid as well. When changing the trans fluid, I recommend going to the dealer and ask them for a "Trans Flush."
94-MBC-220/03-ML320
motioneffects,thanks.I think if i'm going to the dealer it will cost me afortune right. I guesss it will cost me @ around maybe like $400.00 four hundred dollars. thats pretty expensive.thanks.I appreciate.
