ML320 Window issue Not the Switch
Old Feb 21, 2008 | 04:12 PM
brklyncam's Avatar
2001 ML320
I already did the Switch-(thanks for all the info, really easy) Now i can hear the motor working but the window is not moving. Simply it is as if the window is off track. My question is this....How do I take off the door panel? I have removed the screw under the SRS airbag and removed the little plastic piece around the door handle. Do I just pry the sucka off now or are there more screws?................Thanks for the help.....
Old Feb 21, 2008 | 06:01 PM
brklyncam's Avatar
2001 ML320
sovled it...now i need more help
So i got the door panel off and can see the actual track the window sits on and other metal grooved pieces....the grooved piece attached to the motor is working and moving but for some reason something is not connected right becuase the window track sits still. Any help woul dbe greatly appreciated.
thanks
Old Feb 23, 2008 | 11:35 PM
Gullwing's Avatar
1987 190E 2.3
most likely needs a new regulator
Old Feb 27, 2008 | 01:01 AM
pcy's Avatar
pcy
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
Window regulator is riveted to the door frame. So, unless you are good with mechanical tools (including drilling out the old rivets and putting the new rivets), I would say find an independent mechanic. ML door mechanism is not much different than any other car's.
I am assuming that the window regulator is the culprit.
