Sunroof issue.
Old Mar 11, 2008 | 07:28 PM
advans's Avatar
C55 ///AMG, 535xi
Sunroof issue.
Hi All,
I recently disconnected my battery on the 163 and my sunroof doesn't "close".
I understand that I have to resyncronize my sunroof? I closed it with the manual close tool, now the sunroof opens, tilts and closes. but only 2 of the 4 functions work on the control!
I can only push back, which opens the sunroof.
I can also only push up, which closes the sunroof, then tilts up. The glass doesnt stop. I kinda have to "let go" on time so the sunroof closes.
How DO I resyncronize this? any help would be appreciated.
-advans
Old Mar 23, 2008 | 10:32 PM
MBtech1's Avatar
2011 C 300 4-Matic
To re-synchronize it you just open it up and then press the switch up (tilt position) till it closes and then tilts open. Keep holding it for a few seconds and you will hear a click. That means its synchronized. BTW the switch is 2 position. If you push it lightly its the first position, then if you push it harder, you will feel the second position. You want to use the 1st position for synchronizing.
