security system lights quit working
Old Mar 14, 2008 | 11:29 PM
rocknroad's Avatar
Bone stock ML320 and a Beast ///M Roadster
when I lock the car using the fob the lights no linger flash however they do flash when I unlock. what's the problem?
Old Mar 15, 2008 | 09:40 AM
Boost&Cubes's Avatar
04 E55
I've had this problem several times on my wifes '01ML.
Disconnect the battery Ground under the hood for ~1minute (to be safe) and this should bring things back.
Think of these MBs as Microsoft Windows - they need to be reset once in a while.
Just be sure to have the Comand radio Security Code handy because after you disconnect the battery, it will not work again until you re-enter the code.
Good Luck.
Old Mar 15, 2008 | 05:01 PM
rocknroad's Avatar
gave it a shot - no go. I also noticed the rear gate will no longer lock with the rest of the car. I wonder if one of the relays is bad.
Old Mar 15, 2008 | 05:54 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Most likely tailgate lock actuator is bad and that too would effect the lights as it flashes only after it confirms that all doors are locked.
Old Mar 15, 2008 | 06:15 PM
rocknroad's Avatar
makes perfect sense, where do I get one?
Old Mar 15, 2008 | 10:31 PM
sosh's Avatar
Dealer is the best bet. Stay away from any E Bay stuff. Its not expensive, however the rear hatch must be opened up to replace it meaning that you will have to take the interior panel off of it.
Old Mar 20, 2008 | 10:17 AM
mihir_d's Avatar
2000 ML320 2006 SLK 350
Tailgate lock actuator has gone bad on my 2000 ML too..
In my case, the lights etc. all work fine through the lock/unlock sequence - but my rear hatch will not power lock.
I too am guessing the hatch lock actuator is bad...this is the 3rd lock actuator that has gone bad on my ML in the 112K miles/8 years..
Does any one know of any DIY instructions around to open the hatch inner panel to get to the actuator? I am thinking of DIYing it this summer..
Old Mar 20, 2008 | 10:51 PM
rocknroad's Avatar
I'm geting the actuator soon and plan to install. I'll post pics and notes of the DIY.
