Special Tool for Ball Joint Replacement - ML320
Old Apr 23, 2008 | 09:03 PM
aolsen's Avatar
2013 S550, CLS500, ‘03 SL500, “92 190E Sportline
Hey guys, I'm usually on the W203 forums, but I'm helping a friend of mine. He drives a 2002 ML320, needs new front ball joints. Indy shop wants too much money, my father is a Mechanic and will be doing the repair. Is there a special tool needed to perform this? I did some research and it seems we'll need the Mercedes Benz M-Class Pin Wrench Ball Joint Socket Tool. I've seen threads about ball joints repairs for the ML, but haven't gotten a clear answer.
Is there anything else we'll need? Thanks...
Old Sep 1, 2010 | 09:51 AM
sdanville's Avatar
ml320
NOTHING HERE ABOUT BALL JOINTS. I just bought a pair for my ML320. I will have to post what I did soon. My best sorce Mercedesshop.com seems to be gone.
I found this...at peach something site. Copy and paste. I suspect he left out a few things,
Like remove tire and wheel, jack up, take off nut with special wrench, bang out with hammer,tap in with hammer snug to avoid buying a torque wrench.
Ball joint replacement on an ML is an easy job! The old ones just KNOCK out with a hammer & the replacements are held in with a LARGE nut at the bottom.
ONLY problem is getting the SPECIAL nut to the correct torque, special tool required!
__________________
MERCEDES Benz Master Guild Technician (6 TIMES)
ASE Master Technician
Mercedes Benz Star Technician (2 times)
40 years foreign automotive repair
mbdoc-pe@hotmail.com
Old Dec 18, 2010 | 12:48 PM
sdanville's Avatar
ml320
hey Aolsen did you replace the ball joints ?
I would like to hear the post operation results.
Old Dec 28, 2010 | 08:58 AM
anjy834u's Avatar
Mercedes Benz S 550
with the help of Mercedes Benz M-Class Pin Wrench Ball Joint Socket Tool get the issue fixed but get it done by a professional.
Old Jan 5, 2011 | 02:38 PM
PHML's Avatar
2011 GLK350 P1, Multi-media & AMG Pkg; 2010 E350 w/ prem 2; 2018 4Runner SR5 Prem. 4x4
autozone sells ball joint puller for cheap....I bought mines for $12....used it for my Lexus and Mercedes.
Old Jan 19, 2011 | 06:23 PM
NeedsWings's Avatar
01 slk320, 01 e55, 02 c32, 06 ml500
i just replaced all the lower ball joints on my 2000 ml320, you will need an air hammer to get them out and large pipe wrench to get back in
Old Feb 4, 2011 | 05:12 PM
ML 500 mz's Avatar
2003 ML 500
Ball joint repair
I dropped my ML500 ( 03 with 83K) at MB dealer for PA state inspection. I then went to a friends service station having my daughters BMW tires rotated/balance and alignment when the MB dealer called me with the bad news. I needed lower ball joints to pass inspection. Price was $872.32. I checked with the service station I was at, Best he could was $660.00. A difference of $212.00. A nice savings but, at the time, not worth the bs of jockeying the cars around. I had the dealer do the job. Point is, for a bit more money the MB dealer did a good job with OE grade parts. Anyway you look at it, it ain't cheap.
Old Feb 16, 2011 | 04:24 PM
sdanville's Avatar
ml320
it aint cheap if you pay to have it done.
Yesterday I replaced an outer tie rod on the ML320.
1) remove wheel. 2) Nut off ball joint 3) Hit housing ball joint goes through to shock it out. 3) loosen lock nut at other end. screw out tie rod 25 revolutions. Replace.
Cost. $25.00
90% cured the fuzzy steering feel. Next is the front lower ball joints.
$17.69 each for Karlyn ball joints.
Old Feb 17, 2011 | 06:41 AM
ML 500 mz's Avatar
2003 ML 500
Amen to that...not cheap if you pay to have work done
I try to do as much as I can on the ML. When time for plugs, pads, etc., no problem for DIY. You said cost for lower ball joints at Auto Zone @ $17.00 each. I checked with a friend that owns an Auto Parts store prior to having work done and was quoted $96.00 each.... lower ball joints for ML500 (03). Maybe for ML500 a much different type ball joint?? Or, I'm going to start shopping at Auto Zone.
Thanks for the info...
Old Feb 17, 2011 | 06:47 AM
ML 500 mz's Avatar
2003 ML 500
Question No mention of Auto Zone
My mistake. Where did you get the ***** joints price? Because that's going to be my new Auto Parts store. Thanks...
