ML 320 Alignment / Wheel Pulling ?
OR FEEL A LITTLE UNSTABLE??
DRIFT TO LEFT OR RIGHT AFTER A FEW SECONDS IS NORMAL
SETTING THE TOW A LITTLE MORE POSITIVE CAN HELP THE VEHICLE FEEL MORE STABLE.
Driver's body weight may influence to have front left axle lower, that cause a tendency to pull sometimes to the left.
Please check the clearance between ground and front fender arch while you are sitting on driver's seat.
If the clearande of the left side is lower than the right side, you could adjust by front torsion bar.
I suspect when the vehicle "pulls" to the left you are in the left lane of a multilane highway. When you are on secondary roads the vehicle will pull to the right. ML's will be directionally neutral on a truly flat level surface but will respond to side to side slope.
Imagine rolling a ball across a hillside, the ball will turn downhill. your ML is doing the same.
