Is there an TRANSMISSION MOUNT for the ML? (interesting problem also)
Old Aug 20, 2008 | 11:42 PM
jtse's Avatar
I changed my engine mounts on both side but seems to still have vibration that is really annoying at idle and can't seem to solve the problem. When the car is in Drive and stop at the Red Light, If i pull the windows up or using any Power draining thing, the car Vibrates vigorously......but it stops after i let go of the windows switches....What could be the problem? Spark plugs? Spark wires? or what not? (scratching HEAD....)
Old Aug 26, 2008 | 05:30 PM
angeleye328i's Avatar
First, how old is your battery? If you say 3-5 years then replace battery should solve your problem.
Old Sep 1, 2008 | 05:34 AM
alphonsohall's Avatar
ML270CDI
Yes, there is a rubber tranny mount......it is located at the rear end of the t/case and sandwiched between the transfer case and the chassis crossmember.
Old Sep 1, 2008 | 10:48 AM
advans's Avatar
C55 ///AMG, 535xi
yeap, my tranny mount broke down on be countless times
Old Sep 4, 2008 | 04:17 AM
Gullwing's Avatar
1987 190E 2.3
Could be the tranny mount, simple enough to replace.
Comon problem (mainly C230 1.8k engines) alternator goes bad and with any extra load on the engine is shakes very bad.
Old Sep 5, 2008 | 07:34 AM
advans's Avatar
C55 ///AMG, 535xi
it broke down on my ML500 a million times, haven't happened to my C320 yet.
