Unusual Tire Wear 2003 ML 500
I am having a problem with the tire wear I am experiencing unusual tire wear on the inside shoulders of all four tires. These tires are Toyo Proxes S/T 275/55R17 and have about 25000km's on them.
I have inspected the suspension and steering and have found only a slight play in the right rear wheel bearing and slight play in the lower ball joint, both of which are on order but nothing to explain why all four tires are having the same problem.
The unit handles and still drives very well, giving no indication of alignment issues. is there any thoughts to what the cause might be or has anybody seen this before?
EDIT:The 32 PSI is what the vendor and I decided when I bought the tires because the Continentals I had originally showed signs of overinflation when we took them off.
