Help! Hood Locked and won't open
Old Sep 9, 2008 | 05:08 PM
nrml430's Avatar
00' ML430
Went to change my oil this morning on my 00' Ml430, and went to pull the hood release inside the truck and hood would not pop up. I've tried pushing up and down on the the hood while someone is inside pulling on the release...did not work. I've grabbed the cable with pliers and pulled on it incase it was stuck... did not work. I have search around on this forum and others to see if others have had this problem with no luck. Does anyone know how to access the latch from outside the vehicle to pop the hood?
Old Dec 31, 2008 | 02:36 PM
jim.knight's Avatar
ml320
were you ever able to get the hood open?
I have the same problem and could use some help!
Thanks -
