Dropped key remote in WATER
Dropped Key Remote in WATER, is there anyway of drying out the remote.(not working now) I sprayed wd40 in all opening, but still no good... my remote has a cracked button cover so the water went inside... any ideas? thanks
key issue
I did the same thing, forgot about key in pocket on jetski....! It never worked again. I know there are un-programmed keyes on Ebay cheap...Check with your local dealer and see if they will program it and switch-out the actual cut key from your other one.....
