ML500 - Doors keep locking/unlocking/locking
Old Nov 5, 2008 | 05:43 PM
Gooseguy84's Avatar
Soon to be Sl55 :)
I have a new problem with my 2001 ML500. All of a sudden the auto door looks are going crazy. Every time I come to a stop at a red light or stop sign, and then accelerate again the door locks unlock themselves and then lock again. When I get into the car for the first time and start driving they do this as well.
When I am driving normally on the road this does not happen. Has anyone else had this same problem? If so what did you do to fix it?
Thanks!!!
PS- I dont frequent this forum that much so if you had this can you email me at lobell355@gmail.com Thanks again!
Old Nov 6, 2008 | 02:20 PM
55fanatic's Avatar
00 MB ML55, 91 Toyota Supra Turbo(sold), 06 E500(gone), 03 BMW M3
you should try searching...
Old Nov 25, 2008 | 04:59 AM
1stChendeng's Avatar
2005 ML350 Sport
I am new here but had same issue with a Cadillac I had. Turned out to be the computer because that controls all safety modules. I hope this help you out
Old Nov 25, 2008 | 11:13 AM
55fanatic's Avatar
I know your issue... you have machine gunning door locks...
if you look at all you doors when they start flipping out, one door will not lock, that door lock actuator needs to be replaced
the reason they do this when you just start moving is because at 10mph the ML is programmed to lock the doors if there is an unlocked door... because the actuator is broken, it tries to lock everytime it passes 10mph...
This has been covered in a number of threads but I thought I would point you to the search function... "give a man a fish, he eats for a day, teach a man to fish, he eats for a life time"
Old Nov 25, 2008 | 06:42 PM
steffo_'s Avatar
ML320, and... Santa Fé -07
I had a similar problem on my ML 320..
Funny thing is it was because of the battery the locks went haywire :P
Try recharging your battery or replace it, That's what we did
Old Dec 7, 2008 | 07:35 PM
Stiggs's Avatar
2003 CLK55
Did you ever get those machine gunning locks fixed?
Old Sep 26, 2021 | 03:22 PM
convicted's Avatar
1998 CLK 320
I'm having a similar issue with my 2003 ML500.
Full auto machine gun locks, but my issue happens when I try to lock all doors from the inside switch.
All doors are affected.
I've searched my *** off -.and I can't find the fix.
Any and all help is appreciated.
Old Oct 14, 2021 | 12:20 AM
gsfent's Avatar
W163 ML500 w/Kleeman headers (gone but not forgotten); R63
I have had this happen. From memory, it is a bad door lock actuator. You should be able to manually lock the other doors. Don't remember this being too expensive of a repair.
Regards,
Jerry
Old Oct 17, 2021 | 01:23 PM
convicted's Avatar
1998 CLK 320
I haven't check the others, but I can't manually lock the driver's door.
Old Oct 17, 2021 | 03:47 PM
gsfent's Avatar
You should be able to lock the drivers door from the inside (front passenger seat and reach over), It is done as a safety measure so it is harder to lock yourself out of the car.
Regards,
Jerry
Old Oct 17, 2021 | 09:27 PM
convicted's Avatar
1998 CLK 320
Okay, thanks for the response.
I can manually lock the rear doors from the passenger seat (w/the key out), but I can't lock either of the front doors. They just "pop" back up to the unlocked position.
Any advice?
Old Oct 18, 2021 | 10:20 AM
gsfent's Avatar
Any advice?
Can't help you on that one. When stationary, you should be able to lock the doors. Someone with more knowledge/experience will have to step in.
Good luck getting it sorted.
Regards,
Jerry
Old Oct 18, 2021 | 08:19 PM
convicted's Avatar
1998 CLK 320
Thanks for the effort.
