Thule / Yakima Racks Info needed ~advice needed?
Old Nov 10, 2008 | 05:15 PM
s4play's Avatar
01 S2000, E46 M3, 99 ML320
hey guys,
Snow season is coming up and I figured this would be the year I finally get a rack for my car.
I was on the Thule site and it's pretty confusing. After I select my car, they ask if the car is equiped with factory rack?
My car is a 1999 ML and it has the two tie down rails that run front to back - but it seems Thule needs a cross-bar rack too?
I got this list of parts:
450 Crossroad $159.00
LB58 Load Bars $69.00
91726 Universal PullTop6 $199
Do I really need all 3 parts to complete my rack?
Looking to buy a simple rack setup if anyone is selling there , PM ME!
rick
Old Nov 10, 2008 | 10:15 PM
lkchris's Avatar
'10 CL550, '12 GL550
Racks for MLs indeed mount to the side rails.
Then, accessories mount to the rack.
You've listed what you indeed require.
Mercedes dealers sell crossbars, too.
There's no such thing as a basket or box or bike carrier or ski rack that uses only the side rails.
Old Nov 19, 2008 | 09:30 PM
jonesy66's Avatar
ML55 AMG
The Thule rack I have for my ML55 is a "clamp" style. It is used for the MB SUV's as well as the Honda Odessey MV's...it is adjustable for width and uses a simple screw on lock down (with a key) type clamp.
Yakima DOES NOT make one....only Thule to the best of my knowledge. It is the square bar type and all Thule attachemnets can be applied...as a matter of fact all Yakima can be retrofitted with special fittings to fit Thule and vice versa...
Good luck
Old Nov 20, 2008 | 01:58 AM
s4play's Avatar
thanks guys for the info!
I just bought the entire setup which basically consist of 4 parts:
1) Item 450 Crossroad pieces $159
2) Item LB58 Load Bars $65
3) Item 91726 PullTop 6 holder $199
4) Item 544 Locks $49
total: $472.00
Install took me less than 1 hour and was very easy. Hope this info helps others who want to get this done.
thanks
rick
Old Dec 10, 2008 | 01:15 AM
gwml55's Avatar
2003 ML55
Good luck
i have a yakima setup for my ml
Old Dec 22, 2008 | 12:02 AM
ARFNSX's Avatar
G500-500E-ML500-NSX M3-M4-LP640-911C4S-S2000
Originally Posted by s4play
hey guys,
rick
I also had a Yakima for my LandCruiser but nothing yet for the ML.
Good seeing you here on these boards too Rick
